I took my boat out for the first time this season last saturday after getting it serviced by my local service guy (ie tune up and new plugs) 2 weeks ago. The motor starts fine, however ever since owning the motor (just on 12mths now) I have only been able to keep it running in idle and at low speed with the choke. If I stop using the choke it stalls. It runs fine at high speeds but its when I am coming back into the jetty and have to really idle along at a slow speed that I have problems. Even after running the motor for sometime it still stalls at low speed.
I tested it again tonight and noticed that if I use the primer bulb it actually keeps the motor running. Could this be a fuel pump issue? or even the carby low speed adjustment levers need playing with?
Any advise would be helpful as apart from this low speed running problem the motor runs perfect.
