Hi,
I purchased a motor as stated in the title.
I had a problem though that the motor would go up but not down.
I took to a boat shop and they said the valve body bleed screw was stripped and couldnt be removed easilr without probably damagine the port as they will need to drill it out and extract it.
Im now looking for another valve body or a solution.
The Pump is a 3 wire motor and the valve body is a 2 hose pump.
I have seen alot of the same type of valve bodys for chryslers thats exactly the same except they are 4 hose?
I ave attached photos for you to see, if someone can give me some pointer i would appreciate it. I dont mind completely changing the moror and wiring if thats the case.
Cheers
Cheers
