JohnnyGuy
- Aug 24, 2017
- 192
Hey all,
I have a 1976 15hp Johnson (15r76a), which I currently have the powerhead off of to replace upper thrust mounts.
I have a '87 15hp parts motor on hand and was wondering if it would be worth it to change out the stock square exhaust tuner for the round one found on my '87 parts motor, along with swapping Reed plates to bring my '76 up to date with the 15hp mods that happened later.
I've never touched the Reed's before, I am assuming it's a simple swap?
If I swap to the round exhaust tuner, do I leave the short copper water tube it has at the back in place? My 76 has no tell-tale just the "blubber"/exhaust relief hole at back center and I am curious if this would alter the way I check to ensure the motor is pumping water...
TIA for your comments.
JG
JG
