I can start my boat up without any problem and run it as long as I want, but when I turn off the motor. When I go try to re-start the motor the starter clicks like it isn't getting enough voltage. I replaced the battery with a new 100 amp, and replaced the positive cable and terminal post. I am going to change the negative cable this week. I spoke with the boat shop and they recommend that I change the Rectifier? Should I change the voltage regulator or is that part of the rectifier assembly? Anyone got any thoughts on this? <br />Thanks,<br />Rick
