Johnson 1982 35hp
wlas
Is it possible to get a new female red connector , someone cut the end off when I first got the motor
fireman57
Should be able to find used harness on the online auction site. Plenty of them I'm sure.
fireman57
Pretty much the site was talking about but didn't want to put it on here.
wlas
I was hoping i could just replace the connector, to bad, that's all i need, I got a good deal on the engine so I can just buy a harness. Thank you for the input
matt167
the red connector was used for years... you could just cut a connector off another harness if you want to... but that's a lot of soldering/ heat shrink and then your left with connections that are actually brittle
