Hello. This is my first post so if I violate etiquette, my apologies.
I have a John 1987 110 HP V4 2 stroke motor that is new to me. I've had it out half a dozen times since I got it and the only problems I have had were that sometimes when I'd go to low RPM, it would die. I replaced the plugs because they looked a bit black and I figured it's a cheap enough solution. Well, that didn't help. I read countless places that suggested to do a decarb and saw several ways to do that. I opted for the 16 ounces of seafoam to 1 gallon of fuel. That seems to have helped it idle and run low RPMs much better... but while doing that, I discovered that I appear to have a water leak somewhere between the lower unit and the power head. I suspect the gasket that goes between the two, but I'm not sure and was hoping you guys could advise. I took a video of the problem and posted it to Youtube. That video is available here: https://youtu.be/kLWvYc-OV54.
Note, I can't be sure but I don't think it was leaking water like this before. Maybe it's doing it because of the water pressure from the hose? I'm taking it out again on Sunday so it will be interesting to see how it does then.
