Johnson 1988 vro 225 hp fixing up a Frankenstein
kcassells
I started working on this motor this summer. Hasn't been wet for about 5 years. Running high on idle @2500 rpm on hose. Chased out some air leaks etc. Pulled carbs, hoses, gaskets to manifold.
The primer fittings below had no threads at all and were tapered as if "push in." The ports were not threaded either. Carbs with fittings pic and fittings out of carb.
Here are some pics, let me know if you seen this before.
Thanks.
Assembly
Running
View attachment nicey .MOV
View attachment Engine Freakin doing its job 5 16 23.MOV
Drivewayboater2
Had some experience with go kart racing carbs that had press fit brass fittings. Had to be sure they are round and true to seal properly.
kcassells
My confusion is the part reference shows them threaded. I want to replace whereas they are not checked or filtered. Anyone with further insight appreciated.
Check Valve and Filter Assembly 0392988
flyingscott
why would they be filtered? if you are worried put a little loctite on them and press them back in. You pulled them out and they weren't threaded then. Why would they be threaded back in? They are just a primer nipple. Stop overthinking this
kcassells
Hey thanks for the get back. I need to order 1 and was asking for a reference.
Is this the correct part?
kcassells
Scott,
Im not over thinking it, yes they are push in so does anyone on this forum have a part number. What a bunch of back talk.
Scott over think that. phewww
There are quite a few sites that show part # on the --" cylinder / crankcase "---Parts page.----Easy to look up I think.---Starts with 325
kcassells
Yes though unfortunately they are all shown threaded. I guess I'll take a shot with the one shown for fit.
On another note parts started arriving so got some time in breaking down the reeds.
Appreciate your help.
Well---Item #11 for a 1988 model 225 is listed at $9.86 on one site.---Part # starts with 325 .
kcassells
Found that part # on 2 different sites at the $9.86 factory price.
Racer
I thought I posted back to you on fri. Must of gotten pulled away for work. So I did find a lot of 3 for $14.00. Should be here Tues.
Thanks.
kcassells
Drive em in with a 5/32 deep well socket, taper locks em in
Thanks Faz, will do. Ant type of adhesive or sealant recommended.
Do any of you guys have any thoughts on my manual saying to use check valves?
I think if I need checks I could just put them in line with the tees or related fittings.
These fittings are not checked. Will that cause a problem? What came out aren't checked either.
Thanks.
Faztbullet
Primer nipples are free flow as when the primer is off it is the check valve.
