Johnson 1997 150HP ficht oil alarm at low speed
moons
Hello
I am writing from Mexico. Last weekend while fishing at low speed the no oil light and buzzer appear. I turn off the motor and re start it the no oil light gone but after 2 minutes at low speed the light appear again. The alarm did not activat at high speed.
I turn off the motor and check the hoses from oil injector to intake air and Gas Mix and no oil on the hoses. I check the oil return line and it has oil. Injector is ok not open circuit! there are 26 volts on injector while motor running ! This weekend I will connect lap top to see codes! unfortunatelly not outboard certified mechanics on Mexico
I will apprecita any help or comments.
aerobat
Master Chief Petty Officer
Re: Johnson 1997 150HP ficht oil alarm at low speed
i have currently exactly the same problem on my 2000 ficht ram 150... hopefully we can go thru this together and its a small thing...
i have also plenty of oil in the return line- so pump seems working. it may be the pressure switch or maybe a fault in the tank sensor. when its the injector assembly its here in germany expensive as hell.
please report your codes !
moons
This is what
This is the homework for this weeked.
1;Verify oil pressure at oil pump between 4 to 20 psi according Manual.
2;Conect lap top to see code from not oil 34 injector or ecu 35 switch or pump.
3;check if on high speed I have oil flow thru the hoses from oil injector to intake air hoses.
Unfortunatelly I have no oil presence from injector to intake air hoses or fuel premix.
aerobat
confirm : you have NO oil in the injector houses at injector outlets?
moons
correct not oil on none of the 7 outputs from the manifold.
aerobat
check for a blocked supply from the pump to the injector . and maybe you have truly a faulty injector -my houses out af the injector are full with oil, with no air bubbles or something like this.
moons
I already check oil flow from pump to oil injector and is ok. What I suspect is low pressure on oil pump, faulty injector or ECU wrong.
My Doubt is because I already check injector and no open circuit on coil, voltage at injector is between 26 to 27 volts.
This weekend I will check oil pump pressure to see if is ok.
I will appraciate any help.
aerobat
do you have the code readout already? my problem maybe is gone... after several phones with evinrude germany i got the following hints :
1-verify all oil lines are perfectly sealed without any leaks. i had the supply line minor leaky with a loose fitting and fixed it ( but dont believe this was the problem)
2-remove and shake-yes SHAKE the oil tank to see if the oil sensor in the tank is maybe stuck
3-remove and spray with contact spray the cables which regard to the oil pressure switch.
i did it totay and my problem is currently go. the engine worked without problmes for an hour, for more i did not had time.
well- currently i did not changed anything and the problem dissapeared as fast as it has come. but i must say its a stupid thing... first i have here no possibility for plugging the engine on a laptop and second - when it appeared it can appear again. i did not really found any real fault and it would be to nice to be real to believe it is premanently fixed.
in your situation i worry you have no oil at injector houses- this was never the case at me when the "no oil" warning sounded from one second to another.
lets keep updated !
moons
This weeked I will connect the computer to check fail codes.
I read manual and pressure on oil pump must be above 6 PSI constantlly. I suspect this could be the issue if not I will sent the ECU to DFI.
The only thing worry is because there is not oil at hoses from injector manifold to air intakes!
aerobat
like written in my other post- my engine runs now again. i found a slight leaky supply line and checked and sparayed all oil related sensor connections. but i never had NO oil at the manifold outlet.
report what the codes say at your engine. i dont think its the ECU in your case. maybe a bad injector manifold.
