Johnson 200 GT
Scott 77
Hello guys I’m new here here is what I got going on. Took engine apart to hone cylinders & re-ring. Found some of the rods have a copper look. Does anyone know what this is.
Perhaps they are copper plated during the manufacturing / heat treating process.
Scott 77
Maybe I have no idea. Can u guys tell me which rings I need for this motor it is a 1992 Johnson 200 GT VJ 200 SLENS It has been bored .020 want get it rite first time. Also what is the correct sealing material for sealing the block & intake. Thank you
Are they factory pistons or after market.----I do know and did copper plating of parts myself.----Copper plating was removed from surfaces that were to be hardened , such as bearing surfaces.----The carbon is absorbed by the steel.----Carbon does not go through the copper.------Sort of like using masking tape when painting !!!
Scott 77
I’m not sure if they are factory. Can u tell me how to tell please. I do have manual
Scott 77
Here is a photo of pistons & rods if u could let me know if they are factory or not, trying to get parts ordered. Thanks
Pictures like that do not help.-----Any numbers & size indication on them.
Wiseco pistons.-----0.020" O/S -----3 port and 3 starboard.----Only use wiseco replacement rings.------What issues did you have that leads you to replace the rings ??
Scott 77
No real issue see signs of wear when replacing head because of stripped plug. It has lost power over last couple yrs. cylinders look good some of crosshatching left. Wanted to get to it before something bad happened. Should I take to machine shop to check or hone & put back together?
Scott 77
Racerone can u help me source these replacement rings. Part no. Place to order from I’m having trouble finding them found some but not sure. Could u please give me a hand. Thanks
find --wiseco--- online.------Call them at the local office / distributor.------Your location ?
