JODY1970
- Mar 15, 2020
- 15
ok guys my 1997 Johnson 200hp model J200TXEUA is giving me a fit. it has a bad idle and cough and will cut off at idle. hardly will idle for a few seconds.Here is what ive done.
*changed all plugs to Champion QL78YC
*changed Fuel filters and primer bulb with OEM bulb
*removed carbs and cleaned and rebuilt with OEM kits
*replaced all fuel lines at engine
*pumped fuel into clear container and let sit overnight found no water in fuel
*replaced VRO with new $200 bypass fuel pump from MasterTech
*compression is within 5 psi of all cyl. 77-82 psi
*set carb floats to level position when turned upside down
*set air idle screws to 6 turns out after light seat. ive tried 4 to 6 turns out
*cleaned throttle body on engine. cleaned all 4 holes behind side plate at top and 2 holes on left side behind plate
*Re Torqued throttle bodies
*replaced side cover gaskets on throttle bodies
*checked link and synch and found it perfect. all butterflies closed at idle and working in synch
*i did find idle is only at 550 rps under way at idle
Any help would be great. Im a 30 year Caterpillar diesel technician so im a hands on guy. Dont like the dealers if I can do it...
