Johnson 200 ocean pro magnets
wm1600
I have a 1993 johnson ocean pro. recently it melted a stator. When I pulled the flywheel, I found the magnets (outter) are loose. Some of the magnets are broken in half (2) and one magnet is chipped.
Should I replace the chipped magnet?
GA_Boater
Here's your photo. You put it in a Visitor Message to yourself so very few would see it. If you use Phpobucket or another photo hosting site, you can post larger pictures. Using PB, copy the IMG code and paste it in the body of the message.
fetch
