I have an '03, 9.9 four stroke Johnson, model J10TBL4ST (made by Suzuki). It runs, but at half RPM and seems to be missing on the bottom clyinder. I get a very good spark across a 7/16" gap on both spark plug wires. If I bypass the the top spark plug to my gap-jump tool, the motor runs, but misses and usually dies when running on only the bottom cylinder. If I bypass the bottom spark plug to my gap-jump tool, the motor runs fairly smooth when running on only the top cylinder. I switched the top & bottom spark plugs to see if I had one bad spark plug and it runs no different.
Is it the coil (it has only one with two outputs) or possibly the cdi box? Can I test them on this model with a digital multimeter? This is a very low hour motor and has been stored inside, all connections look new. The spark plug thread is smaller than my compression guage adapters, therefore I have not tested it yet, other than with my thumb over the hole to feel pressure and vacuum present.
