Hi,
The above motor has run like a top for many years. It last ran approx 3months ago with no problems. I just hooked it up to the hose for a pre-departure check and noticed oil streaming down the lower leg. Removed cover and saw oil coming from seal at carb cover. I removed the carb cover and drained about 1/2 cup of oil on top of what already escaped. Once cleaned up and without carb cover on, engine cranked and ran fine. It looks like the lower most carb was the oiliest, but I haven't a clue what to do to remedy problem or what the problem is. I have not replaced the carb cover yet because that is obviously the culprit or somehow rrelated. I have posted pictures of the front of the engine here.
http://picasaweb.google.com/winfieldh/Johnson200?feat=directlink
Thanks for any suggestions.
Winfield
Winfield
