1991 Johnson 200hp J200TXEIB
I recently removed my lower unit to replace impellar and forgot to adjust shift rod height, so the reverse is not engaging properly. When I put the lower unit back on I tightened the shift rod bolt to tight and twisted the head off. I don't think it will be hard to tap out but there is very little room to reach it. Can I loosen the lower cowl to make room?? I do not want to remove the carbs & intake unless needed. Any advice greatly appreciated.
