JOHNSON 225HP 1990
RIGGER1
The rpm meter would not work and battary was not being charged replaced the recificier and those problems were solved then engine would run great but not shut off even with the kill switch changed the power pack and that solved that problem but now will idle great and run slow under load but as soon as WOT the engine dies did not have the problem before need help
JB
Re: JOHNSON 225HP 1990
Hello, Rigger.<br /><br />You are on the wrong section of the board.<br /><br />Try Outboard Engines, etc.<br /><br />Good luck. :)
