johnson 25 hp elec. start. elec choke?
richdavis69
I have a 1975 johnson elec. start. ON the carb there is a cylinder with rubber bootie on the end with wires coning off the back. Appears to be tied into the choke, can anyone tell me what this is and how to assure itr works. Electric start is only so good when I have to go to the back of the boat and choke it Any info on this would be greatly appreciated. Cylinder hAS A STRAP THAT HOLDS IN IN THE MIDDLE STRAP APPEARS TO BE CRACKED IN TWO ALLOWING cylinder to slide a little, does this need to be tight? and how does this work. Even if I am way off base I would still like ot know what it si and how it effects the carbelec choke.jpg
AlTn
Re: johnson 25 hp elec. start. elec choke?
if you'll go to marineengine.com and find your year, hp, and look at the carb diagram..you'll see this choke solenoid..it just actuates the choke from the remote...you should see the rod actuate the choke linkage when the solenoid is energized....be prepared for sticker shock
richdavis69
Can you give me the run down in as many details as possibel on how the thing works, Does it automatically close the chose whilst starting engine? How does it work?
lindy46
It is a manual remote choke activated by 12 volts applied either by pushing in the keyswitch or by a push button choke switch. The bracket should hold it tight in place.
AlTn
look at the choke plate and linkage while someone else < or you with a remote starter switch > tries to start the engine or push on the choke button..don't know your setup..you should see the rod come out of the solenoid
lindy46
If it's not wired, just apply 12 volts to the wire coming off the solenoid and ground to the case. It should pull the rod on the solenoid in, activating the choke.
AlTn
yeah, what Lindy said, "In."
