JOHNSON 25HP - how old - how good
EDDYSTONE EEL
Johnson 25hp 2 stroke serial number: A7350237
Nothing else known about it sorry
Does anyone know the year of build and are/were these motors any good ?
Is there a "common fault" or something which should be "checked" when inspecting one.
Any help welcome
Thank you
samo_ott
Re: JOHNSON 25HP - how old - how good
The model number should be beside the serial number on the transom. If you really cant find it, post a picture of it.
HighTrim
If the transom id has been removed, look for the welch plug. It is about the size of a quarter, and will have the model number on it. Look to the top rear of the motor.
If that too has been removed, your motor was probably stolen at some time ;)
F_R
That serial number should be around 1988. The model number will be something like J25RLCCN, or similar. They are good motors.
EDDYSTONE EEL
Hi all
Thanks for all your comments and advice
Will check for the model number, 1988 sounds right I guess but will update when I get chance to get the model number.
Cheers
EDDYSTONE EEL
ALMOST SPOT ON
The model number is AJ25RACUR and from what someone else told me that would make it 1987
Thanks again for all your help guys (or gals)
HighTrim
87 is correct.....good guesstimate by the serial FR
Pony
I have the 1988 version of that motor..............they are fantastic.
