No Midrange or Wide Open Throttle. 1988 Johnson 25HP, Starts fine, runs good at low speed. When I open it up it only gets to about 6 MPH. I rebuild carb yesterday, sprayed through all the ports, replaced valves, gaskets and still have the same problem. I can see the butterfly inside wide open. I've disconnected the linkage and manually gave it throttle and still no wide open throttle. I don't really think there is any midrange either. I did have a marina tune it up this winter.
