Roma's Boat
- Aug 7, 2012
- 9
Howdy folks, 2 Q's: Have two identical 25RL70E's. 1. one has a (freeze crack?) above prop unit on lower unit. Will it leak oil into water? Is this a major problem that needs repaired? "JB weld" a good fix? 2. second motor has ominous warning tag: "do not start, pump is broken". Is there a way to test this without causing motor damage? -Newbie here with some decent mechanical skills.
