Captain Jeff
 - Jun 15, 2005
 - 159
Hello,
1985 Johnson 2HP. I am attempting to change the water pump on this guy but the driveshaft seems to be stuck in the crankshaft. I have turned the motor upside down and let penetrating oil run down the driveshaft several times with no luck. There is obviously no shift rod to disconnect and I don't want to put too much pressure on the LU and damage the housing or water pump. Does anyone have any tricks to get the lower unit off? Thank you in advance!
