magnanimous
- Dec 22, 2008
- 7
Hello everyone
I am having problems with water not pumping around the engine (i.e. telltale is not pumping out water). I have discovered after replacing the waterpump that water gushes out near the top of the gear case. In my attempt to remove the gear case one of the bolts sheared off (without much torque applied!) In any case are there just two bolts holding on the gear case for removal? I'm guessing the drive shaft will simple pop out or is it more complicated than that? I have attached a picture to show a schematic.
Any help would be great thanks. I would prefer not to have to buy the manual at this stage
