Johnnielund
- Nov 14, 2002
- 91
I have a 1990 Johnson 30 Hp tiller (sn J30RESB) converted to a long shaft. This past weekend I experienced a problem shifting from reverse to neutral. When moving the shift handle from reverse to neutral, the reverse does not disengage. Shifter must be moved to forward then back to neutral. This does not seem to be the case when shifting from forward to neutral. Could this be an adjustment or could it be a more serious problem, such as clutch dogs?
