Hello,
I need to change short for long transom with a kit.
I worry about this, because the exhaust system's resonance length is increased about 11 cm.
This will cut maximum power a bit, because exhaust charging will happen at lower speed.
On the other hand maximum torque will increase due to better cylinder filling.
I prefer better power, so I consider measures to prevent this.
Is there a different exhaust tube (diffusor) for this ?
The series long transom versions of the 30 hp seem to have no different parts, which may shift back the resonance point to the short transom level.
Greeting from Germany
Peter
Peter
