Hi, i am new to i Boats, I just bought a 14foot Fiberglas with 33hpjohnson for 300$. It is not getting spark but when i hook up a tester it gets a little light. Im thinking it may be the coil or points? Im in the posses of removing the flywheel but someone had broken off one of the 3 bolts that u use to bolt the puller to. I hope i get that out today! Also the starter seems to not get enough power to turn over the engine, i hooked the battery up and still same thing. How hard is it to rebuild a starter?
What would you think it could be?
what oil should i use in the lower gear case? How hard is it to change the water impeller. Thanks Matt
I am going to pick up a manual if i figure out the spark problem.
