Johnson 35 Sea Horse
tejedarichard
Hi I just took this boat I bought out for the first time and it seemed to smoke a little more than all the other boats on the water. Is there any reason for this? It is a 1968 Chrysler boat I'm pretty sure it's the original engine but not positive. They said it was rebuilt. Can this be a mixture of gas and oil problem.Any help is appreciated. thanks.
BoatBuoy
Re: Johnson 35 Sea Horse
Johnson made 35hp from 1957-59 and didn't make any more until 1976. Due to the design, materials, etc, the models from the 50's used a richer oil mix than the later ones. So if it's from the 50's, then it will smoke more if it's being fed the correct gas/oil mix. If you get the model number from the metal tag on the transom clamp, we can tell you exactly what the mix should be.
ezeke
8)You would think that the moderator would cancel the duplicate with the fewest responses.
rwise
If it is not a chyrsler engine, most likely it is not the original engine! Post the model number from it and you will get more info.
