Johnson 35HP (1983) Wont start. Backfires.
Jknowl2
I am a new boat owner and I have a Johnson 35HP (1983). It wont start it only backfires. I have run a new hose and connections from the gas can to the engine and put in new spark plugs. Any Ideas?
Paul Moir
Re: Johnson 35HP (1983) Wont start. Backfires.
Does it backfire out the exhaust with a BANG or out the carburetor (sneeze)?
If it is out the exhaust, try swapping the spark plug wires first.
JB
If that doesn't help you may have a sheared flywheel key.
JUSTINTIME
timing is definitely off, so flywheel is off our your trigger need adjustment
F_R
Coil leads swapped on the power pack?
mikesea
I agree with the flywheel key,if its jut a bit off your not running.
Texasmark
Hey JB, you stole my response........ 8)
Mark
Jknowl2
Jknowl2
yes, its out of the exhaust with a bang
D
DJ
Guest
Out the exhaust, with a bang inicates a timing issue. It is easiest to make sure the plug wires are on the right cylinder. The top coil goes to the top plug.
G DANE
Coils can also have swapped place on cylinderhead, making wire placement looking right, but being wrong. Not first time, done that myselves.
