Johnson 3hp - Help
LaChonce
I have a old Johnson 3hp outboard motor, model # JW22C, Serial # E2750999. I need a set of rings and a head gasket.<br />Does anyone know where I can get parts?<br />Last, can you tell me what year the above motor is?<br /><br />Thanks for any help.<br /><br />Dan
bubbakat
Re: Johnson 3hp - Help
1967 JH-JHL-22 <br />fuel mix 50:1<br />spark plugs champion J6C gap at 30<br /><br /> ck with your local johnson dealer I will see if I can find you a source
JB
I get 1967 for both the JW-22 and the JH-22. I think they differ only in the leg.<br /><br />For extended low speed operation use the Champion J6C. For high speed operation use the J4C. Gap either at .030 and gap the points at .020.<br /><br />Fuel mix is 50:1.<br /><br />I think all that is what Bubbakat meant, just mixed the model numbers.
