Johnson 4.5 pullstart replacement
safetysam1
I have a 1983 Johnson 4.5 seahorse outboard model #J5RHCTA and was wondering what the correct procedure for putting on a new pull rope
because last season the original one broke. I would appreciate any help
Thank-You and happy boating!
Joe Reeves
Re: Johnson 4.5 pullstart replacement
(Manual Starter Cord Installation)
(This pertains to the vertical type of Manual Starters such as the 9.5hp and later 4.5/6/8hp models etc)
(J. Reeves)
1 - Have a pair of vice grips handy set so that they will grab the top of the starter spindle tightly but will not damage it.
2 - Using a large screwdriver inserted into the top of the starter spindle, wind the starter in a counter clockwise direction 12 to 14 turns, stopping so that the cord locking slot is facing the away from the engine.
3 - Lock the spindle in that position with the vice grips, letting the vice grips lay against the flywheel.
4 - Insert the cord as needed and make sure it is retained properly at that slot.
5 - Feed the cord out the starter cord hole at the front of the engine and attach the handle.
6 - Grip the cord tightly so that the spindle cannot spin around rapidly, then release the vice grips.
7 - Allow the cord to be withdrawn slowly around the spindle.
safetysam1
Thanks Joe for the info. I'm going back out to try this on my motor. It sounds
pretty easy but the "blown-up" picture that I got from
(www.Evinrude.com) for that starter does not call anything the "spindle"
so I am somewhat confused.
safetysam1
well I just got the pullrope put back on.
Thank-you again!
