Johnson 4.5HP- double check model year and water flow...
1lastweekend
Considering purchasing a Johnson 4.5HP, saw it run today and it seemed to run fine...The question is do I have the right year of the motor? The model # is J5RCSS, which should mean Johnson 5hp, rope start, and CS equals model year 1980 I believe. The designation for shaft length is a blank for 15" (which this motor is). Does anyone know what the last "S" stands for in the model #? I thought it was for a sailing designation but that doesn't seem right...
Also when I ran it in a test tank, there appeared to be no pee-hole or water discharge tube other than the spray of water coming out of the exhaust on the upper portion of the leg- is this normal for a 1980 4.5HP? I looked everywhere around, under and inside the lower cowling for any type of rubber discharge hose and found absolutely nothing...Want to make sure I am not missing anything if I decide to buy this motor...Thanks
jbuote
The S at the end is a model run or suffix.. Yes.. it's a 1980 5hp (4.9.. lol) with 15" shaft..
​I think that spray of water is correct in the upper exhaust, but not an expert here either..
Others will correct me if I'm wrong on that for sure.. :)
​I might consider doing a compression test on it, and spark test too just as a pre-buy checkout should you decide to move forward with it.. (Edit: Always a good idea to change the water pump impellor when you buy a used engine. Even if seller says it's good..)
But again.. Still pretty new to outboards myself.
​Hope it helps somewhat..
Vic.S
Yes a 1980 standard shaft 4.5 HP model
As said above the final letter after the date code is just a production suffix
You can see the full model number code system at http://shop.evinrude.com/media/document/ModelNumberReference.pdf
As you have discovered these 4.5 hp models no not have a cooling water telltale but you should see a spray of water from the exhaust back pressure relief port.
tpenfield
I have the same motor in a long shaft (J5RLCSS) and it DOES have the pee hole. I happened to be running it yesterday. :) The pee hole is located above the exhaust port.
Maybe the motor that you are looking at has a clog.
Vic.S
I stand corrected on that. I was thinking of the 4HP models
1lastweekend
Thanks for the feedback all, I am going to look at it and run it again tonight, we'll see whats up after that...
jimwalt
Let us know if you buy it and how much you paid okay? Good luck!
1lastweekend
No Title
Ok so the mystery deepens...Here are some detailed pics of the underside of the cowling and top of the shaft- no telltale hole that I can see. There was a hole just forward of where tpenfield shows where his is on his long shaft, so I thought that was it and it must have been plugged...But it is just a drain hole in the cowling housing. See pics where I inserted a nail in and it just goes into empty space inside the housing.
I ended up buying the motor and got it for a good price. As I said it runs great, compression is 100 and 102, lower unit lube was nice and clear, no discoloration or peeling paint on the head, strong spark to both cylinders. I looked at videos of a couple 1980 Johnson 4.5's on Youtube and they both had telltales and exhaust water discharge, but this motor seems to be different. If anyone has any insight I would love to find out more...
1lastweekend
No Title
Great call tpenfield! After some cleaning I saw the hole- covered in grime...Cleaned with some water and a small wire, clear water came pouring out of the hole. Now to run it and make sure impeller is working...Thanks guys, I feel I got a good deal on the motor even if I need to change the impeller.
tpenfield
Glad you got it sorted out :thumb:
I paid $200 for my motor - long shaft - which I got to use as a kicker for my sailboat. It took a while to get the motor "tuned-up"/"dialed in" but now it seems to start easily and runs well.
jimwalt
So you're killing me................. How much did you pay for your motor? :)
1lastweekend
Sorry forgot that part, he wanted 350 but I got him down to 275 because I wasn't sure if it needed an impeller, also the pull starter is a weird design and the plastic wheel gear doesn't engage all the time, so needs a little work...
tpenfield
​Yes, I am not a big fan of the pull starter mechanism, but have gotten used to it.
