johnson 40 hp carb problem
Jerryiius
I have a 1986 40 hp johnson i have rebuilt both carbs starts great,, runs good till full throttle .Witout the aid of choke primer pushed in the engine will not go to max rpm. Can anyone help ?? Thanks
EN2
Re: johnson 40 hp carb problem
check your fuel pump pressure.if vro 3PSI .REG FUELpump 1.5psi.
EN2
check your fuel pump pressure.if vro 3PSI .REG FUELpump 1.5psi.@ wot.
tashasdaddy
sound to me you did not remove and clean the high speed jets. thus fuel starvation, at high speeds, hitting the primer adds that extra fuel. if the fuel pump were failing the hitting the primer would not have enough pressure to inject the fuel.
http://forums.iboats.com/showthread.php?t=244013
