johnson 40
MIKE ICENHOUR
Yes it ran great in north carolina get it back in ga. it doesn't run the same.I get it running and then put it in gear and it dies out.Like I said new spark plugs checked fuel lines, tanks,carbs are good what else to check out.any suggestions would be appreciated. :(
steelespike
Re: johnson 40
These symtoms usually indicate poor fuel distribution.If you dont know the motors<br />history go through the fuel system from tank to carb.The problem is most likely a gummed up or dirty carb be sure all passages and jets are clear<br />and float is adjusted correctly and operating <br />smoothly.<br /> Be sure system is clean or it could happen again.
