Johnson 48 HP lower unit removal
Dan Morris
:confused: Johnson 48 HP model #J48ESLCCC (built 1988). How do you remove the lower power unit? I have removed all the bolts off the bottom.It dropped down about an inch but the drive shaft is still connected. How do I disconnect the drive shaft to totally remove the lower unit? The skeg is bent and I need to take the lower unit in so it can be straightened.
petryshyn
Re: Johnson 48 HP lower unit removal
Did you disconnect the shift shaft below the carb?
JB
Hi. Dano.<br /><br />There is a seperate Forum for questions about Outboard Engine Troubles.<br /><br />You will probably get a lot more help over there.<br /><br />Good luck. :)
