Independent Thinker
- Jul 7, 2021
- 9
Hi All,
First post newbie here. Never owned or operated an outboard motor until now.
I stumbled across a 1971 4HP Johnson outboard for free. I'm not a mechanic, but I like fixing things and enjoy learning and the challenge of projects like this - within reason.
I need some help/advise on a couple of items (to start) and would greatly appreciate constructive feedback.
1. Does anyone know where I can find a shop manual for this unit? Free of course!
Motor is currently seized...Flywheel and prop won't budge...Pulled plugs still no go...Currently soaked cylinders for the last three (3) days with PB Blaster and Liquid Wrench...I haven't attempted to rotate the engine yet...
2. Does anyone here know how to get the head off without removing the engine from its lower housing? The bottom two head bolts seem too long and there doesn't appear to be enough clearance get them out with removing the engine from the housing. If my assumption is correct, how/what do I need to remove to get those bottom head bolts out?
current plan
Previous owner said the unit ran great when last used so I'm operating under the assumption that the rings are stuck to the cylinder walls...if/when I get the engine unseized, I'll check for compression and spark and make some decisions from there. What am I missing?
THANKS!
current plan
THANKS!
