johnson 5.5 hp cd19s
adkdave
Hello: I just bought a 5.5 Johnson model cd19s for $200. Is this too much? The seller started it before I purchased. Seems to be OK. I need the fuel mixture ratio (24:1?) the recommended spark plug and gap. How can I know that the impeller is OK without pulling the lower unit apart?
Thanks for your help.
Dave
F_R
Re: johnson 5.5 hp cd19s
It isn't too much if you are happy. That's really what counts, right? Fuel mix is 16:1 or 24:1 depending on who you ask and their opinions. Plug is J6C @ .030". Impeller?? you can't.
1946Zephyr
CD-19s is a 1962. I have an Evinrude the same year for sale, for $350, so you didn't do too bad. Mine has a rebuilt lower unit, new impeller and housing, plus a new ignition system. If you get one without all the new stuff but runs good, it's worth about what you paid. That motor should be run at 24:1. The newer 5.5's (61 and newer) do have a needle bearing set up on the crank and rods, so it's a nicer set up, than the ones of the 50's. The earlier ones that were friction type motors, should be run at 16:1 though.:cool:
lindy46
You have to remove the powerhead to drop the lower unit on those models. That's the only way to change the impeller.
