A friend of mine has a Johnson 5 HP 2 stroke outboard (about 30 years old). It has been revised, but it still has the same troubles.<br />It does start (not easily, but it starts and it keeps running), but when you open the throttle fully, it doesn't give all the power it has (It makes less rpm than it should). In neutral with the throttle full open it sounds like it gives full power, but if you have the throttle full open in forward or reverse it doesn't give the power it should give. Is this a common Johnson problem? (Erm the language barrier makes it a bit difficult to explain it in good english<br />
but I hope/think someone understands
) oh and what is the mix proportion?
