i have a j50tlco 85 50hp missing i pulled the top plug wire no change, pulled bottom wire enjine dies switched coils no change noticed melted tar from under flywheel pulled flywheel charge coil was oozing but it and sensor coil are within specs, with ohmn meter replaced charge coil and power pack after that i noticed the sensor coil had ooze also reads 40 ohmns but have a bad miss do you think i should replace it ?
compression 120 both cyl .or should i check something else:joyous:
