Hi all. I have a 1999 Johnson 5HP and the problem is there is no water coming out the pee-hole. This is what i did: When I changed the impeller with the vanes going the right way there was no water pumping still. So i thought i might have made a mistake and so I switched the vanes the other way (the wrong way). Still did not work so I finally put it in the right way (turning the shaft in a clockwise direction and lowering the housing). When i first started the engine after the new impeller the water ran fine in good amounts but then it died away and only hot air came out. I have heard of a thermostat, which can causes these problems aswell. I do not know where it is. Am i able to change it? and if so where abouts is it? I do not have a manual so please just guide me with a few words of your expertise. Do i ahve to buy a new thermostat or can i just fix the current one? what does the thermostat look like? please help me. I will get a manual when i have the time but i really need to fix this engine fast. Thanks in advance
