I bought a 6hp 1979 johnson motor. The tank had no gas so I put a gallon in a drove it around the lake. Worked fine took it home wnet fishing the next day and filled the tank with gas. The motor started fine, but when I would give it gas would run and then stall. I found if I primed the bulb it would stay running. I bought a kite for the fuel pump and installed it with the same results, if I pull the hose of the carb the prime bulb will shoot the gas out and the pump will squirt gas out but will stop pumping shortly. I have check all the connections and they look good. can someone tell me what is wrong?
