Johnson 60 Hp 1990 Tracker Bass Buggy Won't Stay Cranked
Careyd
First, thanks for taking time to read this, and if you reply with thoughtful info... God Bless You!
It is a Johnson 60 hp engine from a 1990 Bass Buggy. It has sat for about 2 years with soured fuel. I emptied the fuel, refilled with high octane gas and 50:1 oil mix, and replaced the battery. After some patient prodding, I am able to get the engine to start consistently. However, it will almost immediately begin to loose RPM and die unless I engage the ignition fuel thing-a-ma-jig (pushing the key in for fuel flow normally used for starting) every couple of seconds. Using this method, I think the engine would continue to run and run. I actually took it down the river a 1/2 mile and back and it continued to run with me pumping this ignition switch for fuel flow.
2 questions:
1) What is causing likely this and what is the remedy?
2) I need diagrams / photos of this engine with identification to become familiar enough to attempt some maintenance like cleaning the carb or other. I bought an online SELOC manual but it has very limited graphics for me to learn from. The Johnson manual set from that year costs $100 plus as a digital reprint from Johnson's service provider. Suggestions?
Thank you again for your time and help!!!
tashasdaddy
HybridMX6
Re: Johnson 60 Hp 1990 Tracker Bass Buggy Won't Stay Cranked
Also, as for a service manual, take a look for one on ebay, they can be had relatively cheap on there. I've picked up 2 different manuals for under $40 each after shipping.
Agree with TD about the carb and water pump.
