Hi,
I have problem starting my johnson 60 hp outboard when it is warm. When it is cold I start it easily by giving it a little bit of throttle, pushing the key a couple of times and then it fires up. I might need to push the key a couple of times to keep it running in the beginning, but then it runs fine.
If I shut down the engine when it's warm and just after a minute tries to start it there is no problem. The problem is if I let it stay off for a couple of minutes when warm. Then it doesn't matter even if I push the key or what I do. The only solution I found working is to open up the primer solenoid manually by turning it a couple of times back and forth and then start it with little bit of throttle.
My thought right now is that it might be something with the stator so it gets a weak spark when warm, but I'm no expert. Have you seen something similar?
Thanks!
//Andreas
Thanks!
//Andreas
