Strecker25
- Jun 1, 2015
- 100
Hi guys, just was gifted an absolutely mint Johnson 6R-69M. Brought it home and it fired on the second pull. Idles incredibly smooth, throttles up fine, shift,etc.
I am going to be using it on a high pressure floor west marine 310 dinghy. The shaft measures 20", which I have to imagine was the long shaft version? The dink is going to need the motor raised a bit, so I'm up in the air on how to achieve that. My thought is to add about 5" of same thickness plywood to the transom to get the cavitation plate up near the bottom of the hull. I'm guessing converting this to a short shaft is out of the question given the age.
Anyways, any info you all have on this motor would be great (manuals, tips, etc) I went with 50:1 for this first tank.
Are there prop upgrades available for this unit?
Of course this is all a little premature, I have yet to run it on the boat.
Thanks
Thanks
