wolfebrother
- Aug 2, 2006
- 17
Hi, I have Johnson 6hp (1960's model) outboard (model number cdl-23e). It was running when it began to overheat and then it cut out. I changed the impeller and while doing that noticed that the impeller key had sheared so changed that too. Now that it's back together it won't start. I had it in neutral when I changed the impeller and had to pull the starter cord a little before the shaft would push back up into place properly. Any idea what might be the trouble and what I acn do to fix it? Any held would be greatly appreciated!!!!
