The motor cranks fairly well maybe 4 pulls. When giving it throttle it almost chokes out. If I pull out the choke just a little bit it runs like it should, but I have to keep holding the choke or it will die. I have no idea what to check?
Thanks in advance.
also after running for a little while it is really hard to get started. The throttle has to be turned up in order for it to start.
Thanks in advance.
