G'day to all boaties out there. I have a 1986 Johnson 70 that starts and idles fine in the water. Idles at about 1150 rpm. Once i have it warmed up with the fast idle, it will sit and idle but one i try to engage a gear and raise the idle it stalls and sounds like it runs out of fuel. Flick the key and it restarts instantly. I moved the carby butterflys by hand, once off idle it has a flat spot then stalls. I've checked for vacum leaks in the fuel line in case it was sucking air some where any suggestions. Any one
Return emails can also be sent to skiers5@bigpond.net.au or dean.cameron1@defence.gov.au
Thanks Best regards
Dean cameron
Thanks Best regards
Dean cameron
