DAN M VAGOS
- Jul 11, 2008
- 363
Hi all just upgraded to a bigger boat and it came with a 1999 Johnson 70hp. The guy told me he used it in the fall with no problem but it's still 15 outside so I could not test run the engine. Also it came off a ferry and was in they parking lot so there was no water to test it. So I did comp test on it and it was 145+- on all three and it had spark. So for my problem I hot it home and tryed to start it and it just cranked and cranked but he told me his tec fogged it so I new it was going to be hard. After sum time it did fire up but ran like it had a miss but smooth at higher rpm. When I first saw the boat and did my inspection I saw one plug #2 was new and #1/3 where definitely used, well after getting fired up in my yard that one plug still looks new. I moved the plug to #3 and ran it and it still looks new. So what's the chances it's just a bad new plug.
