Johnson 70hp not throttling up
j_c_95
Hi all. I have a 84 70 hp Johnson.
When under load and cold it will start up fine
And get out of the hole with no issues.
After it gets warmed up it will not throttle up
Unless I trim the motor up. Then it will take off and run at full throttle.
I am assuming by reading the threads it could be stator, power pack?
Any help would be greatly appreciated.
boobie
Re: Johnson 70hp not throttling up
When it acts up do a cylinder drop test on it and see if it's hitting on all 3 cylinders.
j_c_95
Boobie
Thanks for the response. I did a cylinder drop test and didn't see any drop in either cylinders. Something else I can check or look for?
boobie
How did you do the test and at what rpm ?? And what cylinders don't respond ??
j_c_95
I put it in a tank of water and started it up pulling 1 plug wire ata time and I had a drop in rpms in each cylinder.
boobie
Did you do this when it was acting up ??
could be a lot of things like a coil failing when hot or a carb needle flooding one cylinder (running rich leading to a fouled plug). A tiny tach is a cheap way to test the coils as you can keep the cowling on during the test so everything under the cowling stays hot. If the tach reads correct when the problem happens then stop the motor and move the tach to a different cylinder (the tach winds around the plug lead so it quick to remove and replace on a different wire). how far are you tilting the motor, a little or until the exhaust is no longer under the water?
xjdriver
Mabey somehow the fuel line is pinched a little with the motor all the way down then when you trim up its fine, lol a thought
j_c_95
Boobie yes I done this as it was acting up as it
Does this always when it's gets hot.
I trim the motor about 3/4 out to get it moving. A
Side not if this will help is when idling after getting hit it will idle high for a few seconds than dropping down back to what I would call normal.
pn
+1 on checking your fuel system. tank to carbs.
