johnson 70hp on 16ft boat
lehkyc
iv got a 16 foot glasspar avalon that i bought a 70hp johnson for. i havent had it in the water yet because i have not finished the restoration. do you think 70hp will be a good fit? it had an old 40 johnson when i bought it. id love to stick with a 40-50hp but i would like to reach higher speeds than 30mph sometimes too. any advice will be appreciated. thanks
BonairII
Re: johnson 70hp on 16ft boat
I've got a '67 80hp on my 16' Avalon. What year is your 70hp?
the machinist
I have been running a 1980 70hp on an old 1979 shallow vee 16' Hewescraft sled for some time, performance is great.
captainmont
40 HP mercury on 16ft deepv and I get up to 30 tops just enough to tube your gonna fly buddy
lehkyc
my motor is a 75' i can tell it has very low hours, under the cowling is spotless and the compression test showed numbers that are factory spec so its got to still be putting out close to 70hp
ezmobee
A 70 should be an ideal motor for most 16' boats.
BonairII
Depending on prop, I'd imagine you'd run in the neighborhood of 40mph or more. I'm getting 34mph with my old Johnson(with a crappy gear ratio) and 10 1/4 X 10 prop. That's with 12 gallons of gas, 350lbs of people, and some gear.
