merc4me62
- Oct 2, 2004
- 9
I do have a new question relating to **Impeller Replacement**
I have replaced impellers on other...smaller engines. On this one (Johnson 115 V4 Crossflow), I have already removed the necessary bolts as described in the Shop Manual; but am having difficulties fully dropping the Cav Plate/Prop unit from the Leg. I am guessing that to *fully drop the bottom/prop assembly* I will somehow...someway, need to release the *Shift Assembly Linkage*.
I have following the shift rod up and into the bottom cowl and see where it connects under the engine BUT, I do not see how to release this (and other potental parts) to extricate this bottom end from the Exhaust Leg.
Fortunately (I guess...?), I don't yet have the impeller kit...it should be arriving in a day or 2 thru the mail.
Please help!
Thank you SO MUCH!
Eric
Please help!
Thank you SO MUCH!
Eric
