Re: johnson 76 35hp
Ya' got battery charging karl? You'll need this to hook up a permanent tacho. If not sure, post the model number.<br /><br />If its remote start with the key on the dash, look for a gray wire. That's the tach signal lead. Use a lead from the ignition (purple) and a ground will get the tacho going.<br /><br />If a side mount control box, you might have a tach plug at the bottom of the box just below the key switch.<br /><br />Let us know...thanks.
