My 1982 Johnson 85 V4 Seahorse has been running OK (but I usually have to start it with starting fluid) Put in a new primer ball and line (didn't fix the problem), SO I cleaned the carb - not only did it not help BUT then it started stalling at idle - SO this weekend I cleaned the fuel line leading to the fuel pump and the fuel screen (it doesn't have a typical fuel filter) and now when I try to pump the prime ball it wont get hard AND clearly the fuel line is leaking at three connections leading to and from the fuel pump?
UGH... why would the fuel lines all the sudden start leaking...? the clamps are all nice and tight
